so i'm trying to use python to automate the generate of survey123 reports and i've finally got it to work with a generic output name but when i try and use the fields to create a smarter file name i get this error:
{"error":{"message":"outputFileName value is invalid: \"SUR_${field}_${completion_date | format:\"MMDDYYYY\"}\"","code":"003","details":[]},"success":false}the output file name i am trying to use is this
'SUR_${field}_${completion_date | format:"MMDDYYYY"}'now i know there is nothing wrong with the filename because if i try to create a report manually on the survey123 website using it the report runs fine and the file has the expected filename
it does work if i remove the format part but i need it in that format unfortunately
any ideas?
thanks
Stu
