I have an AGOO and Survey123 Connect (v3.0.128).
Goal: I would like to use a survey to create a publicly visible web map that displays two geopoints that are automatically connected by a line. The points and line would be immediately visible to the public. The final product will be a web mapping application, story map, or dashboard for a conference icebreaker event where each participant will enter their own location and the location of their favorite artist. A line will be generated automatically between the 2 points, ultimately forming a web. The lines are only for visualization so no routing information is needed.
Questions:
- Is there a Survey123 Connect tutorial or sample survey that shows how to use the repeat to collect two points with one survey123.
- Is it possible to automatically connect the points using survey123 or ArcGIS Online (no routing needed).
Thank you!
