I have a survey form with two geopoint questions. The first has bind::esri:fieldType set to null, and the second has the fieldType left blank. When the survey is submitted, I would expect the coordinates saved as the feature's center, e.g. the point that shows up one a web map, to come from the second Geopoint. Instead, when I submit the survey, it always shows up in the web map at the coordinates of the first, null, geopoint.
I have attached a minimal example: an XLSForm with only two questions, null_geopoint and saved_geopoint. As explained above, the feature produced when the survey is submitted appears at the coordinates provided for null_geopoint, rather than at the coordinates provided for saved_geopoint.
I can fix this by switching the order of the questions. So, it appears that the survey is always saving the coordinates of the first geopoint question, rather than the expected behavior of saving the coordinates of the non-null geopoint question. In the actual survey I am working on, through, it is not feasible to switch the order of the questions. Is there a way to get Survey123 to save coordinates of a geopoint question that is not first as its center?
I'm publishing the survey with Survey123 Connect version 3.11.123 and submitting it with the field app version 3.11.164.
Thanks, Sky
