We recently had some trouble with the Survey123 App. The app was used for the registration of plant species at 44 different field locations.
Those 44 forms were saved in the draft folder during the day, when the app suddenly crashed. After that it was no longer possible to open the app. Only a re-install solved the issue, but all data in the drafts were deleted.
We now try to understand what exactly happened. We learned about the “maximum record count” (1000 records) and we were wondering if this caused the crash. In this regard we were confused about what counts as a record. We assumed that each point (form) counts as one record (regardless of how many species and variables are registered at each point). Is that right? Or do all plant species at one point count into the total record count? In this case - if we would register 30 different species per point - the total amount would be 44x30=1360 records.
However, if it is not the record limit that causes the crash, does the draft folder has any limitation of how many drafts can be stored there at the same time?
Of course, the most likely reason might simply be a conflict between the app and the iPad, but we would like to exclude other possible issues (as those mentioned above).
We would appreciate a lot if someone can help us to understand.
(Btw: we used the newest Survey123 version on an Apple iPad with IOS)
Kind regards,
Ulrike
