I have tried to get a stream service configured from the https://opensky-network.org/api/states/all
There seem to be a problem with this JSON format because it does not create proper geoevent definition.
It does not recognize the "states" object as an Array of objects.
I have tried to manually add the "states" object into the geoevent definition using a Group and string object with Cardinality set to Many.
I would then use the array index (states[5],states[6],states[7]) to Calculate geometry, and states[0] for the TrackID etc using processor.
The JSON return is as follows:
{"time":1518552809,"states":[["ac96b8","AAL2423 ","United States",1518552809,1518552809,-93.4581,44.9529,1150.62,false,116.59,94.3,0,null,1143,"2236",false,0],["aa56db","UAL1711 ","United States",1518552808,1518552809,-80.8667,41.8291,11277.6,false,291.48,97.3,0,null,11376.66,"1031",false,0],["aa56da","UAL2796 ","United States",1518552809,1518552809,-76.0575,39.2978,8229.6,false,266.64,42.03,0.65,null,8435.34,"0753",false,0],["a0cfbd","AAL1852 ","United States",1518552807,1518552807,-67.3843,19.9709,9144,false,218.45,321.21,0,null,9593.58,"2330",false,0],["7c6b2d","JST745 ","Australia",null,1518552775,null,null,null,true,0.19,180,null,null,null,"3662",false,0],["a77eae","N582PU ","United States",1518552809,1518552809,-86.9988,40.4198,228.6,false,39.31,83.99,-1.3,null,342.9,"1200",false,0]]}Thanks in advance for any insights.
