Problem
We’re experiencing serious issues with ArcGIS Server 10.1 stability. Services are crashing very frequently especially geoprocessing and map services which contains rasters. We’re also experiencing error messages like:
- “Unknown Container Exception: org.apache.openejb.client.RemoteFailoverException: Cannot complete request. Retry attempted on 1 servers; nested exception is: \n\tjava.io.IOException: Cannot deternmine server protocol version: Received null/0.0”
- Internal Server Error. Error handling service request : a20c5357-665b-4202-8c45-77d932772de6 [Source: REST]
- Failed to construct instance of service 'xyz'. a20c5357-665b-4202-8c45-77d932772de6 [Source: Server]
- Instance of the service 'xyz' crashed. [Source: Server]
- Internal Server Error. Error handling service request : Cannot obtain a free instance.; nested exception is: com.esri.arcgis.discovery.ejb.ArcGISServerEJBException: com.esri.arcgis.discovery.servicelib.AGSException: bcabe55e-552a-4085-90f4-faaa9ac492a4 [Source: REST]
(The error messages above were extracted from the Log Viewer in ArcGIS Server Manager)
After a server restart, the services will be stable for a couple of hours but after that everything start to give problems again – either being very slow to serve maps or services crashing completely without returning any results.
ArcGIS Server Configuration
- Current Version: 10.11
- Total Map Services Published: 15 (8 of which contains raster images)
- Total Feature Services Published: 7 (1 of which contains raster images)
- Total Geoprocessing Services Published: 21
- ArcGIS Server is accessible from client application through the Web Adaptor (running on IIS)
- All data is stored in two separate geodatabases, which geodatabases are residing on another dedicated data server
- Four data stores are registered with ArcGIS Server – 2 Databases and 2 Folders
- No Extensions are registered with ArcGIS Server
- Web Adaptor and ArcGIS Server are installed on the same Virtual Machine
- Licence Level: ArcGIS for Server Standard
ArcGIS Server Installed Patches/Updates:
- Service Pack 1
- QIP-S-SEC-JAN2015-Patch
- S-LS-Patch
- S-QIP-Patch
- WAI-SEC-Patch
VM Specifications
- OS: Windows Server 2008 R2 Enterprise
- Storage Space: 500GB (currently 428 GB free)
- RAM: 16GB
- CPU: Intel Xeon @ 2.6GHz (quad-core)
Other Info
One must note that the server’s resources are no way near the limit. The CPU is on average always in the 50-60% range when serving a request while there is approx. 6GB of free RAM available for use.
Questions
- From my investigations it looks like it can be a memory problem i.e. ArcGIS Services not utilizing enough memory. Is there any limit of how much memory is used by each service?
- Could it be that the amount of geoprocessing services (21) published on the server are somehow helping to create this issue?
- ArcSDE was not installed since from ArcGIS v10, ArcGIS Desktop supports Direct Connection. Does this make any difference?
- One of the geoprocessing service is a custom ArcPy script which is using the ExportToPDF tool. This was working perfectly until some time ago. Lately it started giving problems as well namely:
- If a webmap contains a raster image, the PDF is generated but no rasters are included in the map – only vectors
- If a webmap contains a couple of vector datasets, the PDF generation will fail
Attempted Solutions
Prior to sending this email, we tried some changes to try and solve the problem.
- Create a new geodatabase and point a new service to it
- Changed the App server max heap size and the SOC max heap size as described in this forum (https://community.esri.com/thread/111267#416933) [Now they are back to the original values]
- Re-created the config-store
- We’re trying to avoid re-building the site (just for the sake of trying) because this means downtime for our customer BUT if this is a solution we can schedule it.
Any help please?
