Hi. I'm assessing the option of providing an mmpk for our field staff who use explorer. This is for our firefighters to access Prefire drawings of buildings that have details useful in emergency response. Currently, they use explorer with an online map, which is publicly accessible and secured via the map service, but they frequently complain about connectivity and also the need to sign in, which is cumbersome and time consuming when time is of the essence and your bumping along in a fire truck :-). This is iOS version of explorer. Latest version.
So, I'm considering these options:
A) Sideload mmpk to their devices and provide a launch link that opens that map from where its loaded in app storage. Since the map would be stored locally there would be no need to sign in to AGOL. Solves the sign in issue, but deployment is not easy.
Set them up to access the mmpk via AGOL. Again, a launch link can assist with downloading the mmpk on first use, and launching it directly on subsequent uses. Users would need to sign in, but I'm thinking they can just stay signed in so that it's less hassle. This simplifies deployment and refreshes to the mmpk, too.
Issues I'm running into:
1) Address search fails when disconnected. If I turn off mobile data and wifi (or go away from wifi hotspot), I'm unable to search for addresses or places. Note that the feature search which i have enabled does work. The mmpk contains a vtpk that I have created from the esri world topo vector basemap. The docs for explorer indicate that address searching is supported by default - Prepare maps for download—Explorer for ArcGIS | Documentation. Under the heading "The following tips will help you make better MMPKs for offline use:"
"By default, maps allow you to search for places, addresses, and coordinates."
Perhaps I missed something in creating the mmpk? Or is this a bug?
2) Launch link to the local mmpk fails when disconnected. It's like this - https://explorer.arcgis.app?itemID=MyMap. This opens explorer without signing in to agol as desired, but it fails to launch the map. If I'm online, it works as expected.
3) Regarding Option B above, the mmpk is only accessible once the user signs in to AGOL. This is expected. The issue is that if a user (who is not already signed in) attempts to access the offline map once they are in the field in a location without connectivity, they can't access the "offline" map, because they need internet access to sign in. Kind of defeats the purpose of an offline map. Is this an issue for others? How to address it? I'm thinking I would instruct users to just always stay signed in... Launch link like -
https://explorer.arcgis.app?itemID=MyItem&portalURL=https://xyz.maps.arcgis.com
Thanks for reading this long post. Appreciate any advice on this.
zc
