Hi there
I have a decimal field that I have calculated from the input that the field worker gave in another field. It is basically a calculation where the area entered by the field worker is divided by 5. The result of this calculation needs to be rounded UP to the nearest integer. So if the answer is 5.1, then the output must round up to 6.
How can I format this output to always round up to the next integer, no matter what the decimal value says? Obviously if the decimal value is 0 then the number won't round up.
