I am developing a Survey123 report template and I am getting the following error [Error: Failed to parse "${RMMAL27_Y_type}". Field "${RMMAL27_Y_type}" does not exist or cannot be found in current parsing scope."].
The field exists in my data and I am copying it straight from the provided examples of how to work with the field for a report template.
- In my customized report template I have the question formatted as:
- Has the jurisdiction pre-identified and documented staging areas and points of distribution (POD) locations for receiving and distributing resources?
${RMMAL27 | selected:"y"} Yes
${#RMMAL27_Y}
${RMMAL27_Y_type}
Type Location Name: ${RMMAL27_Y_name}
Type Location Address: ${RMMAL27_Y_address}, ${RMMAL27_Y_city}, ${RMMAL27_Y_zip_}
${/RMMAL27_Y}
${RMMAL27 | selected:"n"} No
${RMMAL27_N | selected:"no"} No assistance needed.
${RMMAL27_N | selected:"assist"} The jurisdiction needs technical assistance to develop this plan/protocol and identify staging area and POD locations.
Staging Location Notes: ${RMMAL27_N_notes_stage}
POD Location Notes: ${RMMAL27_N_notes_pod}
- In the the downloadable template from survey123 the fields are shown as:
Staging and POD Locations (at least 1 of each)
${#RMMAL27_Y}
Please select the type of location
${RMMAL27_Y_type}
Staging & POD Location- Locality
${RMMAL_27_locality}
Type Location Name
${RMMAL27_Y_name}
Type Location Street Address
Type Location City
${RMMAL27_Y_city}
Type Location Zip Code
${RMMAL27_Y_zip_}
Please select the location on the map
${RMMAL27_Y_geopoint}
${/RMMAL27_Y}
- I'm also getting an error "Error occurred when rendering by the report engine. Failed to parse "${LCAR__2019.ADMIN_FIN40|selected:"100"}".
But the following field name codes are shown in the options to work with fields
| 40. What percentage of time does the Coordinator of Emergency Management and/or staff spend devoted to your emergency management program? | ${ADMIN_FIN40} |
- ${ADMIN_FIN40 | selected:"value of a choice item"} is used for putting a check box beside a choice item.
Input: ${ADMIN_FIN40 | selected:"100"} 100% ${ADMIN_FIN40 | selected:"75"} 75% ${ADMIN_FIN40 | selected:"50"} 50% ${ADMIN_FIN40 | selected:"25"} 25% ${ADMIN_FIN40 | selected:"10"} 10%
The field has a field length constraint of 3 and has a field type of esriFieldTypeSmallInteger
Any help would be appreciated..
