I made a copy of the Address Data Management solution directory in an attempt to start working with my own data. I have my centerlines data where I want it, and will be performing a summary to get the predirs, names and city information out; that summary table will be appended into to the solution's master street name file. Just for fun, I took a quick peak at the task and tried to manually enter a new street before I do the append, and I get this error:
ERROR 000001 Traceback (most recent call last):
File "<string>", line 496, in updateParameters
File "<string>", line 566, in _get_workspace_path
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\__init__.py", line 1273, in Describe
return gp.describe(value, data_type)
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 383, in describe
self._gp.Describe(*gp_fixargs(args, True)))
OSError: "CIMPATH=address_data_management/master_street_names.xml" does not exist
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Not sure what the OS Error is exactly telling me; when I do a search on my C: drive for 'master_street_names.xml' I come up empty. I would have expected to at least find the original from the solution install. All my work thus far has been on the C: drive.
Chris Fox
