HiI'm trying to create a GP-service that uses the python openpyxl 3. party module.When i'm running it from arcmap(Standard), it works like a charm, publich the result as gp-service on the server.When i then sets up the flexviewer 3.0 using the gp-widget - i get an error 000816 tool is not valid, and nothing else.import osimport arcpy import uuid import openpyxl class Toolbox(object): def __init__(self): """Define the toolbox (the name of the toolbox is the name of the .pyt file).""" self.label = "Toolbox" self.alias = "" # List of tool classes associated with this toolbox self.tools = [Tool] class Tool(object): def __init__(self): """Define the tool (tool name is the name of the class).""" self.label = "Tool" self.description = "" self.canRunInBackground = False def getParameterInfo(self): """Define parameter definitions""" param0 = arcpy.Parameter( displayName="FileName", name="filename", datatype="String", parameterType="Required", direction="Input") param0.value = 'OpenPyXl' params = [param0] return params def isLicensed(self): """Set whether tool is licensed to execute.""" return True def updateParameters(self, parameters): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" return def updateMessages(self, parameters): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return def execute(self, parameters, messages): """The source code of the tool.""" wb = openpyxl.Workbook(optimized_write=True) ws = wb.create_sheet() wb_file = r'C:\arcgisserver\directories\arcgisoutput\_ags_' + str(uuid.uuid4()) + '_' + parameters[0].value + '.xlsx' ## arcpy.AddMessage(wb_file) wb.save(wb_file)
this is the python toolbox i'm trying to publish, it's quite simple, the only thing it does is making a xlsx file in the c:\arcgisserver\directories\arcgisoutput folder with the name _ags_UUID_OpenPyXl.xlsxThe output folder is set up in the Datastore on the server.I've tried to copy the openpyxl folder from the python folder to the same folder as the python toolbox, no luck at that.I've tried to add a sys.path.append and the path to the openpyxl folder, no luck at that.somebody please help me, my larger tool wont work before i've solved this problem.
