Good morning all,
I am in the process of setting up my enterprise portal users and I'm curious if it is possible to modify the default login behavior. As the admin, I have several groups configured within my Portal, and each user will be assigned to only one group. Is it possible, when a user logs in to the Portal, for the default screen be the group page to which they are assigned? I have discovered that you can default to the gallery, map, etc, but I see no option for groups for a viewer level user. Any info would be most helpful.
Thanks!
Jeff Miller
