Hi there,
We run an ArcGIS Portal 10.5 in a federated environment. I have a map with a few (34) data points on it. There is a field, that I have defined as text, that I am using to store a URL in it. In the Pop-up manager, I have defined the field as being a 'Rich-text' field. I can enter a URL into this field, and close it and even save the map changes. While in the same instance, I can click on the point on the map, see the field which is rich text, click on it and have it navigate to the URL. However, if I refresh the web page, or close out of the browser and bring up the map again, the URL has vanished from the field. It doesn't seem to be related to how many characters are in the URL, I used something as simple as www.usatoday.com, but the values I'd like to put in there are for other objects in ArcGIS portal. I would greatly appreciate it if someone could indicate where I went a stray so that these Rich text values are saved as desired. Thank you!
