I have a simple attribute rule that works in Pro but fails in the web map/app. All of my other rules work that do not have geometry functions in both. Is there something I am missing? In the web app and Survey123 I get a "missing geometry" error which tells me its not seeing the 'fc' layer.
<SPAN class="keyword token">var</SPAN> fc <SPAN class="operator token">=</SPAN> <SPAN class="token function">FeatureSetByName</SPAN><SPAN class="punctuation token">(</SPAN>$datastore<SPAN class="punctuation token">,</SPAN><SPAN class="string token">'SUDOECMS.DBO.LEGAL'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">'*'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> qtr <SPAN class="operator token">=</SPAN> <SPAN class="token function">FIRST</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="token function">within</SPAN><SPAN class="punctuation token">(</SPAN>$feature<SPAN class="punctuation token">,</SPAN> fc<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN> <SPAN class="operator token">!</SPAN><SPAN class="token function">IsEmpty</SPAN><SPAN class="punctuation token">(</SPAN>qtr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> qtr<SPAN class="punctuation token">.</SPAN>FullDesc
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> $feature<SPAN class="punctuation token">.</SPAN>legaldesc
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
