Hi. I am trying federate Portal with Arcgis Server.
Both Portal and Server are fresh installs on Amazon using the latest 10.3.1 AMI from Esri. (They are on the same EC2 instance).
Portal is set to not require HTTPS. There is an SSL cert installed on the webserver it is on.
The documentation says to change Server to allow both "HTTP And HTTPS", but as soon as I do this, any attempt to login in to the Server Manager (note that the ELB does not has SSL enabled) redirects to HTTPS and fails to load.
Any attempt to federate Portal with this Server then fails, I assume because of the above reason.
Any idea why setting Server to allow both HTTP and HTTPS would cause Server Manager to no longer load?
Cheers,
-Paul
