So in 100.7 the static GeodatabaseSyncTask.ImportGeodatabaseDeltaAsync method is obsolete. The replacement method is now a class method so requires a GeodatabaseSyncTask object, which in turn requires a Uri of a service to Create. This makes no sense, having made this a static method was the correct move a few iterations ago. Why should one need to Create a GeodatabaseSyncTask object? This method should be available offline, there is no reason to need a connection to the underlying service to merge deltas from an already downloaded delta database into an already offline database.
What is the driver behind this? Why would you change something back to the previous less robust approach? Guess I am rolling back to 100.6
Morten Nielsen
Michael Branscomb
Edit: Would appear this change occurred at 100.6, so rolling back to 100.5.
