I am having an issue with ArcGIS Pro and Python - both applications fail to consistently initialise / operate as intended when they do start up.
I have recently been trying to get Python 3 to work in my preferred IDE (PyScripter). After searching through many different Google results I managed to completely decimate my Python installation. I can use ArcMap 10.6 and Python 2.7 applications perfectly. PyScripter still works and I can create Tools as needed, however, whenever there is something requiring Python 3, the application will not work.
ArcGIS Pro - I have installed Pro 2.4 on my machine. The system will load, however when I try to add data or run any tool at all the application will close with no warning error / notification. It is a straight crash. Again, I have completely uninstalled and re-installed it and even tried a repair. Same result each time.
Is there a way to restore my Python installations as intended for use with ArcGIS Pro?
I am running Windows 10 64-bit.
