I have a WebApp in the Dashboard Theme with a map and a couple of graphs using the query widget where I face the problem stated in https://community.esri.com/message/768186-re-problem-with-export-to-csv-from-web-map-app?commentID=768186#comment-768186
I activated the export from the attribute table, then found out that there is this bug, activated the export from the Query widget and wanted to deactivate the export option from the attribute table to avoid confusion of the users. BUUUUUT, when I try to edit the Attribute Table Widget now it keeps loading but without doing anything and I am also not able to tick any of the checkboxes.
All other widgets seem to work fine. Any leads on how to solve this?
EDIT: It seems like this problem is related to the map (or the data used in it) that is used for this application. The attribute widget works with other web maps and apps but for this particular web map it does not matter which theme I use - as soon as I open the widget and close it again it stops working, means: when I open the widget settings again it always shows the export option as ticked no matter what I ticked before plus it runs and runs and runs ...
