Hello there everybody, I have run into a problem.
I am working with shapefiles and using them as tax parcels for my job.
The shapefile is a feature class in a geodatabase, and the issue I am having is that any splits done to the shapefile does not get put in the attribute table properly. If I try to search for it using the attribute table or search for it using the select by features option it will not be found, I have to manually select it from the map itself. This also happens if I create a feature.
I also cannot export the file, if I do export it all the spits that I created disappear and there is no record of them. I will also get a message saying that some features might not have exported correctly.
I am wondering if the file got corrupted.
Is there a way to fix this?
