I've created a web app in web appbuilder for developers v2.0. I downloaded the app and unzipped the contents onto my server at "wwwroot\mapping\northern-bat-research-efforts". My server is IIS so I grabbed the DotNet proxy folder from GitHub and placed it into "wwwroot". I have configured the proxy.config in the DotNet folder and the config.json in my downloaded app folder. I registered the app on my organization account and added the app id to the config.json. I do not see any error messages to see that something is not working, but the map never loads, I just see an endlessly spinning progress circle. I suspect that something is wrong with my proxy setup. The map in question is here: http://accs.uaa.alaska.edu/mapping/northern-bat-research-efforts/index.html
I have tried various solutions proposed in Setting up a Proxy , Setting up a proxy with Web AppBuilder Developer Edition , and What's the proper configuration for proxy.config and config.json for a self-hosted Web AppBuilder for ArcGIS Web Applica…. None seem to address my problem directly.
One bit that I have not understood is converting the DotNet folder to an application in IIS Manager. I have not done anything to that effect as I'm accessing my server remotely. When I try to ping the proxy file http://accs.uaa.alaska.edu/DotNet/proxy.ashx?ping I get a 404 - File or directory not found error. The same error occurs if I attempt to test the proxy at http://accs.uaa.alaska.edu/DotNet/proxy.ashx?http://services.arcgisonline.com/ArcGIS/rest/services/?f=pjson. I suspect that these issues originate from not having converted the DotNet folder to an application.
Here is the proxy section of my config.json file:
"httpProxy": {
"useProxy": true,
"url": "http://accs.uaa.alaska.edu/dotnet/proxy.ashx",
"alwaysUseProxy": false,
"rules": [{
"urlPrefix": "http://uaa-geomatics.maps.arcgis.com",
"proxyUrl": "http://accs.uaa.alaska.edu/dotnet/proxy.ashx"
}And here is what I have entered in the proxy.config file:
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
mustMatch="true">
<serverUrls>
<serverUrl url="http://services.arcgisonline.com/"
matchAll="true"/>
<serverUrl url="http://accs.uaa.alaska.edu/"
matchAll="true"/>
<serverUrl url="http://uaa-geomatics.maps.arcgis.com"
clientId="xxxxxxxxxxxxxxxxx"
clientSecret="xxxxxxxxxxxxxxxxxxxxxxxxxxx"
oauth2Endpoint="https://uaa-geomatics.maps.arcgis.com/sharing/oauth2/"
rateLimit="600"
rateLimitPeriod="60"
matchAll="true" />
</serverUrls>
</ProxyConfig>
<!-- See https://github.com/Esri/resource-proxy -->r more information -->
Any help on where the error is likely occurring and what to do about it would be greatly appreciated. Lastly, if I share both my registered app and the source web map to the public and I do not use secured services, then is it possible to deploy the map to my website without a proxy? Can I just set the "useProxy" to false in my config.json file?
Thanks!
