I'm occasionally seeing the ArcGIS Collector error "An error occured while synchronizing edits." with these messages showing up in the ArcGIS Server logs:
The StandaloneTable:'tablename here' in Map:'Layers' is invalid. The base table definition string "tableowner.tablename" is invalid. Underlying DBMS error [ORA-01012: not logged on Process ID: 26520 Session ID: 912 Serial number: 22779 ] [SDE.DEFAULT]. | System/SyncTools.GPServer |
Has anyone successfully tweaked oracle database, sync or feature service parameters successfully to avoid these errors?
