I have a geo processing service that takes a csv as an input and creates a kernel density. Within ArcMap I can connect to my ArcGIS Server and see the service and run it with an input file.
But when I try and use the REST URL the input file is a GPDataFile so I use this json:
{ "url" : "http://www.arcgis.com/sharing/rest/content/items/90e8bd6c020e4730a412e81f54cb0b08/data" } for the input, but it fails for:
NOTE: Projection Kernel Symbology is just the name of the service.
Error executing tool. Projection_Kernel_Symbology Job ID: j538996bcdb784191a2e1d4c957088332 : ERROR 000840: The value is not a Table View. WARNING 001000: Population field: Field value does not exist ERROR 000840: The value is not a Table View. ERROR 000735: X Field: Value is required ERROR 000735: Y Field: Value is required WARNING 001000: Population field: Field value does not exist
Is there a trick to passing a file or getting better logging on the server? ArcMap is able to use this service, is it using the REST API or does it use python?
