I am trying to update two feature services that belong to one map. All hosted on AGOL.
I have previously never had any trouble however I now get an error right at the end that says:
"Packaging succeeded, but publishing failed. Service cannot be overwritten if Sync is enabled and Replicas exist"
This map can be taken offline in Collector. I assume this means that someone has synced the map on their iPad and I cannot overwrite the feature services until they remove that sync.
Is it possible to see which user has the map synced so I can contact them or can I just override the lock somehow?
Neither of these feature services are editable. So overriding the lock won't orphan any data.
I have looked online and it appears you can do both if you are using a server but no mention of it if everything is hosted on AGOL.
