For the past several months I have been developing a workflow based on Attribute Assistant in the file geodatabase environment. Now I'm looking at a similar deployment in the enterprise gdb environment.
I understand the issue with the Generate ID table not being versioned but I have a couple of questions:
Must the the Generate ID and the Dynamic tables reside in the same enterprise geodatabase that contains those features and tables I'll be applying Attribute Assistant to?
If not, can I keep the Generate ID and Dynamic tables in a file geodatabase instead?
Are there advantages to keeping the two Attribute Assistant specific tables in the same database as the features and tables and are there distinct disadvantages to keep them elsewhere?
mmiller-esristaff
AMuise-esristaff
jmward
