I am trying to publish a toolbox with Arcpy and I cannot as when creating sddraft, I received an error stating :
{(u'ERROR 001243: The xyz/YYparameter is missing a syntax dialog explanation in the item description', 92): []}
I tried to add a description to the arcpy parameter but that does not work so my question is, how do you add a description to a tool so as to avoid this error. There is no mention of it on the help:
Defining parameters in a Python toolbox—Geoprocessing and Python | ArcGIS for Desktop
The publishing works with ArcMap as long as I add a description manually but how to scripts that ?
Many thanks for your help,
Nicolas
