Trying to get Single Sign-On set up on a Portal site.
Our Portal is using active directory, and it works as desired for our typical user - on a physical machine, signed in with their AD credentials.
The issue here is that we have a good chunk of users who use Virtual desktops. Our Virtual Desktop environment sits on a different domain (domain 2) , however users still use their domain accounts from the same domain that our Portal is on (domain 1). The 2 domains have trust relationships or similar to enable this.
Single Sign-On does not work currently for these Virtual users, even though they get to the their virtual desktop with the desired domain 1 AD account.
I was looking at simply adding a trusted domain in the Portal settings for domain 2, but the documentation says wildcards are not supported - so adding *.domain2.myorg.com doesn't work. I don't believe that we can get a fully-qualified name for the domain 2 VDI environment
Restrict cross-domain requests to your portal—Portal for ArcGIS (10.7 and 10.7.1) | ArcGIS Enterprise
I'm thinking we can make this work since the VDI users are using their domain 1 accounts to sign in, but am not sure where to add domain 2 as a trusted domain, or if that's even the right path to go down.
Any thoughts on how to proceed in this scenario to get SSO up and running - it's fairly critical for some applications we have in this Portal.
Thanks -
Allen
