I have two functions
1. First one will crated the feature layer
2. second one will access the same created layer and prints the result.
but when i run my script first time it will print the wrong results. when i run it second time it will shows correct result...
Correct Result:
1. layer which is creating contains only 5 Rows so my script is supposed to print only 5 messages
getting access to map layer 1
getting access to map layer 2
getting access to map layer 3
getting access to map layer 4
getting access to map layer 5
Wrong Result Script running 1st Time:
# import system modules
import arcpy
import math
import sys
import traceback
from arcpy import env
# Class to Build Boundry of Districts
class Build_Boundry:
def __init__(self, workSpace,mapLayerFinal,censusLayer,totalDistricts,mxdLocation):
self.workSpace = workSpace
self.censusLayer = censusLayer
self.mapLayerFinal = mapLayerFinal
self.totalDistricts = totalDistricts
self.mxdLocation = mxdLocation
# Function to Calculate Average of Total Voters in each District
def boundry(self):
arcpy.AddMessage("Building Boundry of Districts ")
if arcpy.Exists(self.mapLayerFinal):
arcpy.AddMessage("Layer Already Exist.....")
print(self.mapLayerFinal)
else:
arcpy.MakeFeatureLayer_management(self.censusLayer, self.mapLayerFinal,"DISTRICT_ID BETWEEN 1 AND "+str(self.totalDistricts),self.workSpace)
# Execute Dissolve using LANDUSE and TAXCODE as Dissolve Fields
arcpy.Dissolve_management(self.mapLayerFinal, str(self.workSpace)+"/"+str(self.mapLayerFinal), "DISTRICT_ID", "","MULTI_PART", "DISSOLVE_LINES")
arcpy.AddMessage("Boundry of Districts Calculated")
mxd = arcpy.mapping.MapDocument(self.mxdLocation)
df = arcpy.mapping.ListDataFrames(mxd, "")[0]
addLayer = arcpy.mapping.Layer(self.mapLayerFinal)
arcpy.mapping.AddLayer(df, addLayer,"BOTTOM")
mxd.save()
arcpy.RefreshTOC()
del mxd, addLayer
return;
# Class to Calculate Compactness
class Calculate_Compactness:
def __init__(self, workSpace,mapLayerFinal):
# Function to Calculate Compactness
def compactness_quotient(self):
arcpy.AddMessage("Calculating Compactness Quotient")
with arcpy.da.SearchCursor(self.mapLayerFinal,["Shape_Area","DISTRICT_ID","Shape_Length"]) as rows:
print "layer "+str(self.mapLayerFinal)
for row in rows:
area = row[0]
district_id = row[1]
perimeter = row[2]
print "getting access to map layer "+str(district_id)
print "Calculating Compactness Quotient Process Complete"
return;
folder = "C:/Users/Abrar ahmad/Desktop/CASES/Rural/Case_1_Boundary_Input" #raw_input("Please select Folder Containing data: ")
mxdLocation = r"C:/Users/Abrar ahmad/Desktop/CASES/Rural/Case_1_Boundary_Input/New_Rwp_Cencus.mxd"
workSpace = "C:/Users/Abrar ahmad/Desktop/CASES/Rural/Case_1_Boundary_Input/Selected_BU2.gdb" #raw_input("Please enter your Work Space: ")
env.workspace = workSpace
censusLayer = "Rural_Area_Rwp"
districtsLayer = "Existing_District_Boundary"
totalDistricts = int(5)
mapLayerFinal = str(districtsLayer)+"_map"
# Function to Build Boundry
boundry = Build_Boundry(workSpace,mapLayerFinal,censusLayer,totalDistricts,mxdLocation)
boundry.boundry()
cc = Calculate_Compactness(workSpace,mapLayerFinal)
cc.compactness_quotient()
