When I attempt to validate our federated servers in Portal (Enterprise 10.5.1) I'm getting red exclamation marks indicating that it is failing. When I log into the Portal Admin and do a validate the status of Failure is returned on both Servers with the Following Message Error: java.lang.Exception: Server returned status code 500. If I go and inspect the Log files in the Portal Administrator I get the following Warning Validation failed for Hosting Server Codes 207053 and Warning validation for federated server failed 207051. These failures have only started happening recently.
I can still access the server managers for both ArcGIS Servers via the Portal without any issues, however I can no longer publish from ArcGIS Pro or created hosted featurelayers from Portal. If I try and add a shapefile from my computer I'm getting ERROR Publish exception 'Exception: Internal Server Error'.
We have an externally signed SSL certificate on the Web Adaptor and ESRI Self Signed Certificate on the individual server components.
I'm wanting to get this sorted before upgrading our environment to 10.6.1.
Any help would be appreciated
Clinton
