In looking at the ArcGIS 10.2 Help - Common clients of Portal for ArcGIS, ArcPad is nowhere to be seen. Granted, the title does say "common," but I am wondering whether ArcPad can be an uncommon client of Portal for ArcGIS. The last line of the aforementioned page does say to check the shortcuts in the Start menu where Portal is installed, but I don't have ready access to the OS where our Portal instance is installed for testing.
Has anyone tried using ArcPad as a client of Portal? If so, does it work? I haven't had much luck searching documentation, any links to definitive (I use that term loosely with Esri's track record of documentation) documentation on the matter?
