Hi guys,
I'm having some troubles with smoothing polygons in arcpy. It works well in ArcMap with exactly the same settings but when I use "arcpy.SmoothPolygon_cartography", the polygons are not smoothed, as shown in the images below:
Original:
Result from arcpy:
Result from ArcMap:
I have attached my code, the original shapefile, the result from ArcMap, and the result from arcpy below. The result from ArcMap is exactly what I want but as I have over 1000 shapefiles to process it's not practical to do it manually in ArcMap.
Also I found this bug: BUG-000117346: The Smooth Polygon tool does not smooth the polygons..
However, I was using the PEAK method.
Any help would be much appreciated.
