I created a SOAP SOE in ArcGIS Server 10.0 and am trying to convert it to 10.2. As part of the SOE, I access a Feature Class from an IGeoDataServer. I used to be able to connect to the ArcGIS Server using the machine name and iterate through the ServerObjectNames, but due to local connections not being supported in 10.2 I can no longer do that. I changed my code to use an internet connection, but keep getting a "bad syntax error" when trying to retrieve the ServerObjectNames. Our ArcGIS server map services are secured using web authentication and AD roles. I tried to put in a valid user but it did not work either.This code works on an ArcGIS console application but not within my SOE. How can I connect to the IGeoDataServer from an SOE?Thanks,Mele private IGeoDataServer InitGeoDataServerFromNetworkServer(String machineName, String
serviceName)
// Create a property set for connection properties.
IPropertySet propertySet = new PropertySetClass();
//propertySet.SetProperty("Machine", machineName);
propertySet.SetProperty("user", @domain\mapuser);
propertySet.SetProperty("password", "1234");
propertySet.SetProperty("CONNECTIONTYPE", "esriConnectionTypeInternet");
propertySet.SetProperty("URL", "http://server/arcgis/rest/services/");
// Connect to the server and get an enumerator for its objects.
IAGSServerConnectionFactory agsServerConnectionFactory = new
AGSServerConnectionFactoryClass();
IAGSServerConnection agsServerConnection = agsServerConnectionFactory.Open
(propertySet, 0);
IAGSEnumServerObjectName enumServerObjectName =
agsServerConnection.ServerObjectNames;
enumServerObjectName.Reset();
// Iterate through the objects to locate the GeoData service.
IAGSServerObjectName serverObjectName = null;
IGeoDataServer geoDataServer = null;
while ((serverObjectName = enumServerObjectName.Next()) != null)
if (serverObjectName.Name == serviceName)
IName name = (IName)serverObjectName;
geoDataServer = (IGeoDataServer)name.Open();
break;
return geoDataServer;
