Hello:
I wanted to share an issue we encountered because I have not found it documented, and it may help others troubleshooting similar ArcGIS Server failures on Linux.
I have essentially the same behavior in two completely separate customer environments, using different Linux distributions and different hypervisors.
Environment 1 – Oracle Linux / VMware
The first environment was running:
- Oracle Linux 9.8
- Oracle Linux UEK 6.12.x
- ArcGIS GeoEvent Server 11.1
- VMware vSphere
The ArcGIS GeoEvent Server installation was fully functional at version 11.1.
We initially attempted to upgrade from 11.1 to 11.3. The software installation completed, but the ArcGIS Server site upgrade failed.
We later encountered the same behavior when testing upgrades involving versions 11.5 and 12.1 LTS.
The failure occurred during the ArcGIS Server site upgrade:
ArcGIS Server upgrade step 2 of 2 : Updating auto-deployed services.
The following error was repeatedly logged:
The server was unable to access the URL
'https://<server-fqdn>:6443/arcgis/services'.
Additional errors included:
0x80004005 - Unidentified Error in '"esri.MessageConnection"'
The stack trace referenced:
com.esri.arcgis.gisclient.AGSServerConnectionFactory.open
This was then followed by:
Failed to create the service 'System/CachingTools.GPServer'.
ArcGIS Server repeatedly attempted to create System/CachingTools.GPServer, but the operation failed each time.
We reviewed the usual possible causes, including available disk space, system requirements, hostname/FQDN resolution, permissions, firewall configuration, directories, and service account access, but nothing explained the failure.
Environment 2 – Ubuntu Linux / Hyper-V
A similar issue occurred for another customer in a completely different environment:
- Ubuntu Linux 22.04.5 LTS
- ArcGIS Server
- Microsoft Hyper-V
In this case, ArcGIS Server installed correctly and all applicable patches were installed successfully.
However, when attempting to create the ArcGIS Server site, the process failed with a similar message indicating that:
The server was unable to access the URL...
Again, firewall rules, permissions, DNS/hostname resolution, directories, connectivity, and other common causes were reviewed without identifying the root cause.
Common factor: CPU instruction set
The interesting common factor between these two otherwise unrelated environments was the CPU presented to the virtual machines.
Both VMs were running on older Intel Xeon processors that supported AVX but did not support AVX2.
This was confirmed directly from Linux using:
grep -o -w -E 'sse4_1|sse4_2|popcnt|aes|avx|avx2|pclmulqdq' /proc/cpuinfo | sort -u
The result was:
aes
avx
pclmulqdq
popcnt
sse4_1
sse4_2
Notice that avx2 was not present.
Test performed
In both customer environments, the VM was shut down and migrated to another virtualization cluster whose hosts used newer Intel Xeon processors supporting AVX2.
No operating system reinstall was performed.
No ArcGIS reinstall was performed.
The same VM was used.
After moving the VM, we ran the same Linux command again:
The new result was:
aes
avx
avx2
pclmulqdq
popcnt
sse4_1
sse4_2
The important difference was that avx2 was now available to the guest operating system.
Result
After moving the Oracle Linux VM to the AVX2-capable host, we ran the ArcGIS Server site upgrade again and it completed successfully.
In the separate Ubuntu/Hyper-V environment, moving the VM to hardware where AVX2 was available also allowed the ArcGIS Server site creation process to complete successfully.
These were two different customers, different Linux distributions, different hypervisors, and different ArcGIS Server workflows, but the behavior was very similar.
Important clarification
At this point, I am not stating that AVX2 is an officially documented requirement for ArcGIS Server.
We have opened support cases with Esri and requested clarification, but so far we have not received confirmation or found documentation specifically stating that ArcGIS Server requires AVX2 in these scenarios.
It is possible that a native library, third-party component, or another dependency used by ArcGIS Server on Linux requires or behaves differently depending on the available CPU instruction set. Only Esri can confirm the actual technical dependency.
What is particularly interesting is that we observed this behavior with ArcGIS Server versions 11.3, 11.5, and 12.1, so it does not appear to be limited to only the newest release.
So far, I have only encountered this behavior on Linux. I have not seen the same issue in our Windows-based ArcGIS Server environments.
I am sharing this in case someone encounters similar symptoms, especially errors such as:
during ArcGIS Server site creation, site upgrade, or creation of system services.
As an additional troubleshooting step, it may be worth checking which CPU instruction sets are actually exposed to the Linux VM and verifying whether avx2 is available.
If possible, testing the same VM on a newer CPU or virtualization host that exposes AVX2 may also help determine whether the underlying processor capabilities are related to the issue.
I would also be interested to know if anyone else in the community has encountered similar behavior or has received confirmation from Esri regarding AVX2 requirements or dependencies for ArcGIS Server on Linux (in these specific cases with ArcGIS Server, since Esri does document dependencies on AVX2 instructions for the Object Data Store and for ArcGIS Notebook Server).
Thanks.
