Hello everyone,
I'm writing this post because we're experiencing an intermittent issue with ArcGIS Portal (version 11.3 on Windows).
Our deployment consists of three machines:
- One hosting Portal for ArcGIS
- One hosting the Web Adaptors
- One hosting ArcGIS Server
At certain times of the day (not always the same), ArcGIS Server Manager logs report the following error:
"Failed to return the service configuration 'Utilities/Geometry.GeometryServer'. Could not connect to the ArcGIS component at URL 'https://ARCGISPORTALMACHINENAME.DOMAIN.IT:7443/arcgis/sharing/rest/content/items/a7dd81351ad8116d'. The ArcGIS component on that machine may not be running or the machine may not be reachable at this time. Error: Read timed out."
The same error may occur for different gpmap/web services, all of which are used by the same application.
The service itself never appears to time out. Instead, it seems that ArcGIS Server is temporarily unable to retrieve the corresponding Portal item. The issue resolves itself after a short time, but it causes the application to stop working during the outage. At the same time, Portal logs do not show any warnings or errors.
IIS timeout settings are at their default values and should not be involved. The issue occurs regardless of whether the application is being used by many users or only a few.
One clue we found points to the antivirus potentially scanning Portal directories and causing the internal request to time out. We are currently testing folder exclusions to verify this hypothesis.
Has anyone experienced a similar issue or can suggest other possible causes?
Thank you in advance for any advice.
L
