Hi all,
I'm using Enterprise 11.5 and using a DigiCert cert.
I haven't had any SSL errors until now. I'm getting an error while running a scheduled model: File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\ssl.py", line 588, in _load_windows_store_certs
self.load_verify_locations(cadata=certs)
ssl.SSLError: [RSA: WRONG_SIGNATURE_LENGTH] wrong signature length (_ssl.c:4047)
So I thought I would do some digging with Esri Tech support. So we tried some cert stuff but I'm still wondering.
I read these docs: Server and Portal
One thing I noticed in the Portal documentation: I import the .pfx and I use Import Certificate Chain and then it says The alias for these certificates will match the alias entered above and be appended with either _root or _intermediate depending on the type of certificate. Then it says "After importing an existing CA-signed certificate, the root and intermediate certificates may have already been imported. These would be listed under Security > SSLCertificates."
I don't have any certs listed except the one .pfx. Does anyone use Import Certificate Chain and it actually lists the root and intermediate certs?
So now I'm thinking I need to export the root and intermediate certs from the .pfx using IIS - Site Bindings - Edit - View - Certification path - click on the root cert - Details - Copy to File and save as a .cer and import them separately into Portal and ArcGIS Server.
Let me know what you think. Thank you!
Andrea
