I have a question about licensing a parallel prod environment. We are going to build it to do some upgrades for our existing Enterprise GIS in AWS. The approach is to build a parallel environment, switch, and then test. We've started to plan the transition with learning our licensing options. We have uncapped licenses for the Server, so it is not a problem. We are concerned about portal. Currently we have 45 Creators in total, 30 are being assigned, 500 Viewers (60 assigned), 50 ArcGIS Pro Advanced (6 assigned).
We are considering this approach: take 5 Creators, 60 Viewers, 6 ArcGIS Pro and create a licensing file for the parallel prod. Update current production.
Or should we take as much as we can from the available Creator licenses? Or it does not matter et all? If everything is okay after the switch, how can we assigned other necessary licenses?
