Hey everyone,
I want to remove the feature layer name. I don't want to rename it because of where it sits in relation to the symbol in the legend. I read in here that you could just rename it but instead of typing just indent and call it good, which does not work, it will not allow it.
I have a published feature service called "Secondary Occurrences". At the moment, the name of the feature layer sits above the symbol, which looks weird. I don't need another label. Below you can see where I put a lower space bar in place of the Feature layer name because it demanded there be something. In other posts they recommend solutions using unique values, which I don't need, or the "space bar" solution mentioned above. Another solution "hide in legend" which is not what I need as I need it to be visible in the legend. Does anyone know how to simply remove / hide the feature layer name while keeping the feature and feature label visible?
Thank you,
ACMB
