Hi All,
I am currently planning a highly available, multi-machine ArcGIS Enterprise deployment on Azure to support a Utility Network transformation for a utility client. The proposed architecture includes two machines each for Portal for ArcGIS, ArcGIS Server, and ArcGIS Data Store.
I wanted to check whether it is feasible to use Azure Application Gateway in place of the ArcGIS Web Adaptor. My thought process is that this approach could potentially help reduce costs associated with additional Azure Virtual Machines that would otherwise be required to host the Web Adaptors.
Has anyone implemented or evaluated this setup? I would appreciate any insights or recommendations regarding compatibility, configuration considerations, or potential limitations.
Thank you,
Kaushik
