Hey all,
I'm running into an issue using Field Maps offline, specifically with a Form for a point feature layer called "transect_plot"; I'm getting an error saying "The form contains unsupported data".
I'll add more detail below, but what I'm having a hard time understanding right now is that I have 3 offline areas defined. In two of those areas, I can add and update a "transect_plot" point; in one of those areas, I see the error and can't add any data. Again this is with the same layer, different offline areas.
My process for creating the layer/form is as follows.
I created the layer in AGOL, created a new map and added the layer to it, then opened the map in Field Maps Designer, and navigated to the Form builder. From here I progressively added Form elements, testing successfully part way through with the offline app on my phone. I continued to add more fields (text, whole integers, doubles, and combo box with an uploaded CSV with ~66 options for different tree species), tested again offline at which point the error appeared.
