Hi ESRI community,
It will be really appreciated if someone has solutions to this issue or has similar problems not resolved.
Issue: The form contains unsupported data error message!
I have 4 related tables to 1 polygon feature layer. Tables have distinct fields but properties are same. When added inspection data via mobile Field Map app, all tables work but except 1 table that gives above error message. Sometimes error shifts to one of the other tables, which has worked before. It is very weird!
Question 1: Can Field Maps (Mobile) hoist more than 3 related tables?
Question 2: Is there a possibility of bug?
Question 3: What is best solution, @esri?
Hoping for the solution soon 🙂
Regards,
Rinchen
