I'm working in ArcGIS Pro. I want to intersect river segments (lines) that go through Open Space (polygons). The problem is that some areas of the river are wide so there are gaps between the river and open space. I created a buffer (100ft) that would capture gaps with Open Space. The buffer did a good job capturing the missing open space. I then did an intersect on the Buffer and Open Space so that I only had those sections of overlap. I want to intersect the Buffer (with open space) with the River (lines) but again I have gaps so I'm missing the river segments where there is open space.
What tool should I be using to find River segments (lines) that cross Open Space (polygons) if there are gaps?
I've included a map of the problem.
Thank you!
