In ArcGIS Pro model builder there is a utility named Get Field Value. The parameters of the tool are an Input Table, a Field (Column Name), and Data Type. You can choose from a long list of data types. One of the data types is "Coordinate System", and this is the one I'm having trouble with. What I'm trying to do is iterate through a table and for each record in the table, I want the Get Field Value to read a coordinate system I will have stored in the table, in a column named [Coor_Sys]. Once it gets the field value, I want to use that as a variable in a later tool (Create Feature Dataset). Here is what I don't know... What EXACTLY should be stored in the [Coor_Sys] column for a downstream tool to recognize the variable as a coordinate system?
Should the contents of the [Coor_Sys] column be text like this:
WGS 1984
NAD 1983 (2011) StatePlane Georgia East FIPS 1001 (US Feet)
OR
Should the contents of the [Coor_Sys] column be a number like this:
4326 (the WKID of WGS 1984)
6445 (the WKID of GA East StatePlane)
OR
Should it be something else?
