Hello Esri Community,
I am working on a project with a dataset of 611 addresses, and I’ve encountered a problem when selecting features by location. In ArcGIS Pro, the selection works as expected—when I select by location, it selects the correct feature. However, when I attempt the same process in QGIS, the feature is not selected, even though the XY coordinates are identical in both software.
Both ArcGIS Pro and QGIS show 7 decimal places for the XY coordinates, but ArcGIS Pro seems to handle the rounding or precision slightly differently. The coordinates for the point and the corresponding vertex of the line match perfectly in ArcGIS Pro, but QGIS does not select the feature as expected.
I have ensured the coordinate system is consistent across both platforms. Despite this, the issue persists, and I am unable to figure out why QGIS is not selecting the feature.
Has anyone experienced a similar issue? Any insights on why this might happen, or suggestions on how to resolve it?
I appreciate any help or advice from the community!
Thank you!
