Greetings community-
In preparation for a radio-telemetry project I would like to explore the potential of using Field Maps to collect spatial data. For manual telemetry (radio-tracking) I determine the direction of the strongest signal for a given tagged animal and collect a bearing for that direction. In the past I have then used Avenza maps to draw a line from my current position in the direction of the bearing I collected. Ideally I will then repeat this process from 3 different locations to triangulate the animal and attempt traveling to the area where the lines cross (or more likely the resulting polygon that is created). This part is easy in Avenza, however exporting and preserving the data is not.
Field Maps seems like a better option to preserve this data and transfer it to my ArcGIS Pro project, however figuring out how to draw a line from a single point and bearing seems less intuitive.
Furthermore if my crew can access internet during their field day my idea is that we would be able to share these bearing lines with each other to assist and expedite the triangulation efforts for multiple animals at the same time.
Any ideas?
Thanks in advance!
