Hello! I'm trying to figure out a way around having to hand trace contour lines on a Georeferenced map image with contour lines, which will be used to create a raster elevation surface.
Steps so far:
-Select the image in contents pane-->right click-->data-->export raster
-Raster to Polygon or Raster to Polyline
-The tools will generate polygons from the contour lines, but each line is over 1000 different small polygons.
I have also tried the Generate Trend Raster tool, but had the same outcome.
Thanks for the help!
