Hi ESRI Community,
We recently upgraded our Pro from 3.1 to 3.4 on our server not knowing the incompatibility it had with our Enterprise version (10.9.1). We began experiencing issues such as an error when trying to publish to our Portal, which states "Python is not installed". Additionally, we see this error when trying to create a hosted feature layer from a template in the Portal. We downgraded back to 3.1 VIA and uninstall and reinstall of Pro, and have worked with tech support to solve the issue through the following means:
-Renaming python folder to Python_old and repairing the ArcGIS Server
-Removing folders related to any past installations of Enterprise aside from our current version, and repairing the ArcGIS Server
-Attempted publishing from both cloned and non cloned environments, both returning the same error
Does anyone have any ideas as to what else we can do before tech support recommends a full uninstall and reinstall of ArcGIS Server? We are pretty much at a loss as to what else we can try, so input is appreciated. Thank you!
