Since we upgraded from ArcGIS Server 11.1 to 11.3, I am facing intermittently an issue with ArcGIS Server: the site is temporarily not available.
Here is a typical output of our monitoring probing both:
- /arcgis/rest/info/healthCheck
- :6443/arcgis/rest/info/healthCheck
If I connect on the VM and try to access manager:
https://localhost:6443/arcgis/manager
I sometimes get a response, sometimes not. Checking the process, everything seems to be in order: ArcGIS Server service started, plently of ArcSOCs processes running. Having a look at the "classic" logs, I dont see anything.
If I check the tomcat logs in "\framework\runtime\tomcat\logs", in "catalina.0", I have the following:
Oct 22, 2024 3:09:15 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
SEVERE: Socket accept failed
java.io.IOException: The specified network name is no longer available
at java.base/sun.nio.ch.Iocp.translateErrorToIOException(Unknown Source)
at java.base/sun.nio.ch.Iocp$EventHandlerTask.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
Oct 22, 2024 3:47:56 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 3:51:02 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 3:56:59 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 3:59:01 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 4:02:57 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 4:06:01 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 4:16:03 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 4:19:03 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 4:23:09 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
Oct 22, 2024 4:44:02 PM org.apache.tomcat.util.net.Nio2Endpoint$Nio2Acceptor failed
As you can see, the error time matches the unavailability detected by the monitoring. Any idea, what could be the issue ?
The only solution I found is to restart the ArcGIS Server service and then it is back to normal.
