Hello all
I am unsure how to word this correctly so bare with me please!
I have two layers (See image) attached.
The layer which has its attribute table on the left side of the attached image needs to have the Post Code field populated. The right attribute table is from my polygon layer of postcode areas.
I am after a way to identify / populate my layer using the centroid of each feature and applying the correct postcode from my postcode layer. I dont fancy manually doing all 1187 features!
I am hoping this is a simple expression I can apply to input the correct postcodes?
Thank you!
