We are currently migrating standalone servers from ArcGIS Server 10.7 Advanced to ArcGIS Server 11.2 Advanced. We have provisioned 11.2 on a fresh VM rather than as an in-place upgrade. The services were then transferred by copying over the existing config folders: "arcgisserver\directories", "arcgisserver\config-store\services", and any registered data stores. As a result, the services appear in the server manager, but cannot be started due to runtime incompatibility - having all been published with the ArcMap runtime and not ArcGIS Pro. From the server manager, it is possible to edit the runtime of each service individually, resulting in a working service where compatible with the newer runtime.
It appears that ESRI had once included a utility to batch this runtime migration:
https://enterprise.arcgis.com/en/server/10.9.1/publish-services/windows/migrate-services-using-the-command-line.htm
Was this utility only available in Server 10.9? It is missing from the stated location in our installation of 11.2: <ArcGIS Server installation location>\tools\UpdateArcMapServices\UpdateArcMapServices.bat
Is anyone able to share a copy of this .bat file? Other ideas for batch runtime migration?
Many thanks.
