Hi there,
We have a database which only the ArcGIS enterprise server can connect to, it's not accessible from the user's PC. Similar to the situation described here.
Publishing a hosted layer fails because at staging and publishing it fails to make a connection. The connection is however correctly registered to the enterprise server data store.
We have a workaround to publish from a VM which is permitted to make a connection to the database. Is it possible to reference a saved data store on the server without having to make connection to it from ArcGIS Pro?
This would be possible if the data was in a file geodatabase and you could see that through the 'Replaced' tab in Service Workspace
Giving access to the database from a users' PC is not possible. As far as I can see, updating this through CIM is only possible once it's been published, and would still fail from a user's PC instead of the VM.
Thanks in advance!
