Hello There,
In ArcGIS Urban release notes for urban February 2024. there is a feature that has been removed.
"The Export Urban database functionality in which the urban database is exported to a file geodatabase is removed. Use the urban model copy workflow instead."
https://doc.arcgis.com/en/urban/latest/get-started/get-started-release-notes.htm
They did mention using copy workflow instead, while the copying option doesn't allow copying outside to another AGOL or even export this urban model in GDB to be imported as it has previously existed.
I am wondering about the reason behind the depreciation of these features and what the are alternative options?
BTW using AGOL Assistant doesn't show the urban model as one allowable item to be modified "View JSON" or even copied neither.
